I’m trying to install Motion Core 11.1.1 but I get this error:
Execute: msiexec.exe /passive /norestart /i “C:\Program Files\D-BOX\Motion Core\Motion Engine\MotionEngine_Setup.msi”
Failed to install Motion Engine. Exit code: 1603
I did also try to uninstall old version and do clean install 11.1.1, but got same error.
I tested to run installer with “run as administrator” same result.
Luckily I have old 11.0.0 installer and that works.
OS is Windows 11 21H2 with latest updates.
Edit: Found the reason. WLAN AutoConfig service must be enabled.
Why do I need this service to be enabled to get 11.1.1 version to work !!!
If I’m asking what rig you have, it might be revelant!
